Need some help on SSD WHS installation.
Status
Not open for further replies.
You say it works using a standard mech hard disk with your config file? can you not image that and or clone to the SSD?
Alternatively resize the partition on the HDD and clone to the SSD?
andy.
It works without the config file for the HDD because it is a 1TB drive. I am not sure how to image/clone the drive. not done that before. Also dont know if it will work with a WHS install?
Status
