Need some help plz....
Permabanned
26 Sep 2012
hello my pc stop display image on monitor my gpu fan is not working but there is a red light on matherboard it CPU LED
can any one plz help thanks
Can you give us some more details please?
Motherboard make/model, same for GPU & power supply, how & when the problem occurred (e.g. did it happen whilst using the machine or was it fine one day and not the next).
my motherboard is asus m5 a97 pro 2 led is on VGA led and boot device led whats that mean?
Please can you re-write this so it's understandable, and also give us the rest of your system spec?
I'm looking at the manual for that motherboard, and there only appears to be LEDs on the board for standby power, DRAM & BIOS flashback.
  1. Standby LED simply means the motherboard has power going to it (a reminder to switch off / disconnect your PSU before changing any hardware)
  2. DRAM LED indicates a memory fault
  3. BIOS Flashback LED lights when you're flashing the BIOS using the USB flashback facility
Which ones of those are on?
No display monitor GPU fan STOP and 2 red leds are on Boot device vga led HELP plz........
MY SPEC
Motherboard-Asus M5A97 PRO
PCU-AMD Bolldozer FX-4 4.20Ghz
GPU-HIS iceQ X HD7850 2Gb Ghz
RAM-8Gb
Hard Drive- 500Gb and 1Tb Portable drive
I was playing and recording and i stop for a break when i come back my monitor was on stand by and after that didnt work any more i check every cable and replace every thing a back again but no work plz need help ?????:confused:
First why did you make another thread with the same problem?
Do you have an onboard graphics? if so try that if that works then your GPU is probably faulty or try another GPU if you have a spare even just a low-end one to see if that's going to work.
