Hey all,
Ive had some excellent suggestion with regards to my PC build, and Im not trying to get some help with regards to a monitor choice.
Main Criteria.
The monitor will need to have a very low response time since it is going to be used for gaming, and ghosting is a big no no.
An HDMI slot and 1080p would be required since I plan to use the monitor in conjuction with my PS3.
Budget
Im looking around £160-£180..though I can probably stretch that if a better monitor is close to that budget.
I would consider a 22" if somone has a very good recommendation.
Any help would be mucho appreciated
Main Criteria.
Budget
