Hi All,
Just about to buy and build a new PC and aside from the all out rage I am feeling in regards the GFX card situation I am also now, happily, seeing a price drop in AM4 MoBo's
This leaves me thinking, now that budget is a bigger concern given what I am going to have to spend on GFX and given the price drops in MoBos do I go higher end B350 (around £100) or lower end x370 (around £120-£130).
Not overly fussed about SLI, prob getting a 580 anyway.
I know the difference is small but that £30 saving is £30 off other components.
Thanks All.
EDIT - As a side point, given the current costs and assuming you have to pick would you go GTX1070 or RX580? Take it as a bit of a survey to help me decide, just add the model choice at the end should you choose to reply to my main point. Thanks!
Thanks All.
