- 22 Aug 2010
- In My Command Center
Im looking for a single slot card that has an HDMI, DP and either another HDMI, DP or DVI like the card below.
I am struggling to find a card like the below that is in stock and has the desired outputs.
Any that I have found have a VGA output which would be unusable in this instance.
Can any of you recommend a card?
Many thanks
XFX R7-250E-ZNP4 Radeon R7 250E 1GB 128-Bit GDDR5 PCI Express 3.0 x16 Support 3 Monitors Video Card
This GTX 1050TI would be perfect except its two slot
Many thanks
