- 14 Jul 2008
- Behind you
Hi all, decided to buy myself TF2 today but then realised it looks garbage compared to what I play on my brothers computer. Anyway I was looking for your help.
Im on a tight budget and am only looking for an upgrade (unless you can find me a PC for 150/200 quid). I want to be able to run TF2 1920x1200 res with everything on high.
Here are the stuffs I have :
AMD Athlon(tm) 64 Processor 3000+ running at 2.01 GHz
767 MB RAM
NVIDIA GeForce FX 5200 (GeForce FX 5200)
My Mobo is a MSI K8N neo platinum edition and supports AGP chipsets. And the crappy type of RAM.
Is it possible with a budget of £200/£150? Or will I have to get a new PC.
I usually only use my PC for browsing the internetz on my Ocuk 24" - However ive had problems in my past that all point to my rig. (DVI not at correct res, random hanging in windows etc).
Right now im happy with my rig to browse the internets but Id like something that can also run tf2/cs:sauce at high res with full details.
Thanks if you reply and if your not then
you meanie!
EDIT:
Just realised I havent told yall I wont be needing a sound card/network card/cd drive/hard drive/case
well actually im lying on the last thing you should see my case, its such a mess and its full of fail (randomly the side panel falls onto my foot if I dare swivel my seat too much). But it runs my computer
If you cant fullfill my criterions please spec me a new rig for a decent price!
767 MB RAM
EDIT:
