Need some help with cables 2 x vga to 1 x vga
26 Oct 2002
Notts
Hi,
Bit confused as to what I need to purchase for setup as below :confused:
Shuttle with onboard graphics VGA
Xbox 360 Output vga
Wanting to connect these two to my Dell 2005fpw is this possible? Need some sort of 2 into1 connector.
Can I run a vga signal through a DVI Cable?
Thanks Dutch
Yeah I think it's possible to get boxes that do this, i had one at work a while ago with two vga inputs, and one connection to my monitor so I could change between pcs whilst using only one monitor. Dunno if it was purchased, or a DIY job, I can have a look if you want, but it won't be till monday. I'd imagine that someone sells them somewhere though.
Thanks for the reply, was beginning to think this wasn’t possible with no replies.
If you could have a look that would be really appreciated.
Thanks Dutch
This is what your looking for (i think,but i have never tested one with an xbox 360)
Two VGA in/One vga out with switch on top to change between the two VGA inputs.
If you buy one,,Make sure it has a switch on it..Some are only controlled by software or pressing special keys on the keyboard.
It's called a KMH switch.
What I used at work has the title "data transfer switch" on it, and it's made by Hills Components.
If you google, you can find one for £10, can't link as i think they're classed as a competitor. (If you can't find it, I can email you the link if you want)
You connect your pc to A, xbox to B, and the moitor to I/O, and use the switch to change between the two.
Edit: Some pictures of what it is I used:
Looks similar to what chaparral posted but without the power supply. You can probabaly tell i used one monitor for two compuers (a dos box and a windows one) but if the xbox uses a vga connector then it should be fine :)
Hope this helps
