Morning All.
So built my new system yesterday but wanted some advise on my fan set-up and whats the best way to handle it.
So currently i have the following custom loop.
360 Rad, GPU, CPU, Pump/res all in the loop. Attached to the Radiator I have 3 Vadar fans pulling air up through the rad. I also have one 3 pin AF120 on the back pulling out and 2 AF 120 on the front pulling in.
So my question is around how to control these fans... So i have a Luxe case with a PWM hub and have the fans set-up as follows.
PWM hub --> CPU fan header
AF 120 in socket 1 of the hub (this is the fan the hub uses to sync voltages withe the other fans)
Socket 2 & 3 AF 120 at the front
The 3 vadar fans are connected to a PWM 3 way splitter that then plugs into the PWM hub. This is all controlled via the motherboard software.
The fan hub is powered by a Sata connection
Now here is where the problem lies.. Last night i popped the top filter off and realized that only two of the three rad fans were spinning at idle... the AF 120 are all spinning... this got me thinking may the PWM fans don't like being controlled by voltage..
So trying to work out whats best..
The mobo has 5 sys fan headers but according to the manual only the CPU header is PWM the rest are voltage controlled.
Would the cpu header be enough to run three pwm fans?
I am thinking ditch the PWM hub altogether and simply plug the 3 way pwm splitter into the CPU header and run the PWM fans from that and then use the system fan headers to run the 3 AF 120 non pwm fans (each on its own header)
Anyone got any advise would be helpful.
I've done this on a couple Enthoo Luxe and Pro cases, but can't remember for sure if there was any stop on PSU filter, but I don't think there is. I only remember that taping the two bottom filters together with about a 5mm gap between them because if they were tight together there the very back of PSU filter was in a little too far and unfiltered air leaking through a small gap at the back.
