Need some help with Resident evil DS
XPE
XPE
9 Jul 2005
Before i go into this i have played the Remake for the Gamecube so i have some knowlage of the game and what i am doing.
im having trouble using the fire/acid rounds with the Bazooka, i try to comine them like i did in the remake but it doesnt seem to work :(
is there something else i should have pick up or do to the rounds to get them to work with the bazooka or is the game being nasty to me :confused:
thanks for any help in advance
not sure exactly what u mean but...
you cannot hold more than 6 rounds in the bazooka
you cannot switch ammo in the bazooka, you have to use all the ammo in the bazooka then reload it with the different ammo
i remember the remake on the gamecube allows you to put up to 78 rounds (of the same type) in the bazooka at once
hope thats what you meant
if not let me know, i'm sure i can help you
good luck and happy hunting !
Thanks a lot, that done it :D
didnt know you had to fire all the round from the bazooka in order to use acid/flame rounds.
in the remake on the cube i remember being able to switch ammo when ever i wanted ;)
