- 9 Dec 2007
I am currently having the most infuriating problem with my PC.
I downloaded and installed Daemon tools, like I have done many times before, and restarted my computer to complete the installation. Upon restart the computer booted normally up until the loading progress bar (Vista64), makes the login screen sound and then the monitor just loses signal from the graphics card - Or at least, thats what appears to be happening - The monitor pops up with a little dialog box in the top left switching between Analog and Digital before finally going in to standby mode.
To make things worse..
Ever since I built this PC I have had a strange problem, in that the keyboard never works at bootup. It works fine on the POST screen to enter BIOS, but then stops functioning entirely until it comes to the passworded login screen for Vista. This means that when I get to the boot options (Safe Mode, Normal etc.) I can't select safe mode, nor can I 'Press Any Key to Boot From DVD..' to try using some sort of repair tool on the Vista DVD.
What can I do? I'm completely at a loss here - Not only as to how it happened, but how I can fix it.
