need some help
20 Aug 2008
my pc that i have just built keeps crashing in eve im running a q6600 4gb of ocz gold 800mhz and a 9800gx2 with a ds5 x48 mobo all stock setting i dont know y this is happing any help would be most appreciated.
need a few more details buddy. Is it just eve crashing or is eve crashing you whole PC.
Is it coming up with error messages ? Does this happen with any other game ? Are you sure your CPU is cool enough ( I once had a problem where my comp kept crashing when it tried running games. Turnt out the heatsink wasnt seated properly.)
just re fitted the frezza pro 7 temps have come down 28-30 c idle they was at 38 -45c core temps now i think about it i should have noticed this but i tought it was the extra heat of the 9800gx2 as it runs very hot its the overclocked evga model thanks for your help and for a quick reply.
not good still crashing in eva this is the error code 0x0000007F (0x0000000d, 0x00000000, 0x00000000, 0x00000000) it realy ******* me off now need more info please help.
if anyone gets this error code its the realtek driver found a good web site that put me straight on to this prob update driver and all is good thanks for you help anyway.
