Need some (possible advanced) help
15 Jun 2009
We use a combination of sysprep and acronis to deploy images of laptops. On these images, we keep the administrator account active for RDP purposes - just incase their account breaks, The admin account has a password on it.
What I'm after is a way to keep the admin account active, but run through oobe, create a new user accound automatically log onto that account from now on.
We've been doing this through netplwiz to automatically logon but this means we have to log on to the admin account first, anyway to save time?
TL;DR - Keep admin account with password, Go through OOBE, Automatic login enabled with new user account.
There are few recommendations I can make that may assist you in achieving your end goal. Ultimately, the solution which best fits your scenario is best determined by testing.
The first suggestion and most scalable solution would be considering utilizing Active Directory Domain Services. Having workstations as part of a domain with AD in place would prevent the need to run the settings below.
Next, there are a few ways in which the administrator account can be enabled. There is a wonderful TechNet Wiki Enable / Disable the Local (Hidden, Built-In) Administrator Account in Windows 7 that provides the steps to 4 ways you can activate the admin account as well as the TechNet library resource Enable and Disable the Built-in Administrator Account. Also, as can be seen in this forum thread from TechNet, Jasonkoh uses the following script added to specialize pass within his XML file:
<component name="Microsoft-Windows-Deployment" processorArchitecture="x86" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<RunSynchronous>
<RunSynchronousCommand wcm:action="add">
<Order>1</Order>
<Path>net user administrator /active:yes</Path>
</RunSynchronousCommand>
Regarding the process of enabling automatic login on the Windows 7 machine, the TechNet library article AutoLogon offers an XML example of how to set autologon properly.
I realize you are currently using sysprep and Acronis; however you may also want to consider the use of the Microsoft Deployment Toolkit (MDT). MDT is completely free and many find it to be extremely beneficial as it combines all of the official Microsoft tools (Sysprep, Windows Automated Installation Kit (Windows AIK), and Windows System Image Manager (WSIM)) into a single workbench interface that can help automate both the imaging and deployment process. WSIM might come in very handy for you as it streamlines the process of creating XML files. The Step-by-Step: Basic Windows Deployment for IT Professionals provides some wonderful guidance on the process of creating an answer file with WSIM. MDT is also compatible with Windows XP, Windows Vista, Windows 7, and Windows Server 2003, 2008, and 2008 R2, which means learning one utility to do all of your deployments. Furthermore, it is exceptionally useful in creating “universal” images as it can easily add or remove drivers or applications from the deployment images.
Just as another tip, you can also use Audit Mode to customize the system should you need to perform customizations to the default profile. By allowing you to log into the system as Administrator, Audit Mode can significantly simplify the customization process. In order to customize the default profile in both Windows Vista and Windows 7 you will need to make your customizations in Audit Mode, and then run Sysprep with an answer file that has the copyprofile setting enabled.
Jessica
Windows Outreach Team – IT Pro
http://www.rt7lite.com/
As well as a lot of other stuff it let's you create users and set one to auto login
I know it's only adding stuff to the XML script file but you can take a look at what it put in there if you want to add it to your own existing script....
I'm not clear what you are really asking though...
If you want a 1 off admin login I would set admin to auto login with no password and uac off then once done turn off auto login and command line set the password and reboot
