- 11 May 2007
I'm thinking of this spec:
Gigabyte GA-P35-DS4 motherboard
Intel Core 2 Duo E4300 1.86ghz & stock cooler (for now)
Seagate 7200.10 320GB SATAII/300 8.5ms 7200RPM 16MB Cache
2 x 1GB Corsair (CM2X1024-5400C4) DDR2-5300/5400 (667/675MHz)
CASE ASONIC XCLIO Server case 5X5.25 6X3.5 2xfloppy 2, 8" fans, temp lcd and leds, possible 12" fan
1 x Lite-on 16 X DVD-ROM SHD-16P1S
1 x Lite-on DVD-Writer SHM-165P6S
and one of these
Point Of View 7600GT 256mb DDR3 DVI HDTV TV Out PCI-E Graphics Card
X1650Pro 256MB GDDR3 DVI TVO HDCP PCI-E Graphics Card
X1950Pro 256MB GDDR3 DVI TVO HDCP PCI-E Graphics Card
I was hoping to overclock the cpu to near 3ghz if possible.
I might want to add a second hard in a few months time.
More or faster memory and a quad cpu in a few years time and there's a slight possibility of a second graphics card in a few years too.
I want to know if the Antec SmartPower 2.0 500w ATX PSU is OK.
http://www.antec.com/uk/support_productInfo_details.php?ProdID=14501
or would this do?
Basiq 500 BP500U -GB 500 Watt PSU
http://www.antec.com/uk/productDetails.php?ProdID=06501
This case seems to be liked and has the 450 watt version i think
http://www.overclockers.co.uk/showproduct.php?prodid=CA-040-AN&tool=3
Someone said Antec are not as good as people though they were but I need a balanced view. If it's no good, would someone suggest a PSU that would cope with my requirememnts and last a few years but needs to be as cheap as possible.
Failing that are there any PSUs or brands to avoid or a list of brands where I can't go wrong?
Thanks
Pete
and one of these
or would this do?
Thanks
Pete
