Hi guys, need some advice on a build. My choice is basically Mini ITX @ £230 or mATX @ £170 both inc del.
The specs of the respective builds are similar, here they are:
Mini ITX:
Aplus Cupid 3 Case - £59.99
http://www.tweaktown.com/reviews/1797/a_cupid_3_mini_itx_htpc_chassis/index.html
Zotac Geforce 9300 PCB04 - £120
C2D E5400 - £50
Total: £229.99 inc delivery
mATX:
Wisdon 410 HTPC Case - £47.99
http://www.wisdon.com.tw/products_xq.asp?ProductNO=256 - very nice case, the internals are also used by a more expensive chieftec model (will need to get a cheap mATX psu with it too)
Or
InWin BL634 Case - £57.96
http://www.in-win.com.tw/products_pccase_series.php?cat_id=1&series_id=44&model_id=187
MSI P7NGM-Digital - £60
C2D E5400 - £50
Total: £167.96 inc delivery.
Not sure which mATX case I'd go for, I think I'd lean to the Wisdon as it'd go well with my amp, even though it's a bit larger.
Anyway, I'm just not sure at all what to do. On one hand I'd love a lovely small system like the Mini ITX, on the other hand, I can get a nigh on identical system, with better upgradability, for £60 less, with which I can buy a 1 TB hdd...
Any advice, or words of wisdom? I'm having real difficulty here!
Cheers guys.
Mini ITX:
C2D E5400 - £50
mATX:
Or
C2D E5400 - £50
Cheers guys.
