12 Mar 2013 at 13:37 #1 The Matrix The Matrix Associate Joined 12 Jul 2012 Posts 988 Not required now. ... Last edited: 12 Mar 2013
12 Mar 2013 at 14:58 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare You will want to fill the 8pin ATX up near the CPU socket with either of those two cables labelled "cpu" from the PSU. The 2X4 will go in side by side to make an 8pin, or use the single 8pin.
12 Mar 2013 at 15:22 #3 The Matrix The Matrix Associate OP Joined 12 Jul 2012 Posts 988 Cheers Sorted it in the end, its just this is the first 8 pin ATX board ive had, better being safe than sorry as they say.
