Hi all,
I'm thinking of changing the Swiftech 120mm rad in my loop for something else and I need some advice on whether I should bother and which rad i should change it for.
Current loop is; >120mm rad+res>cpu block/pump>184mm rad>gpu>
The 120mm rad is only a single row rad but the 184mm rad is a black ice two row one and I've been wondering if I would see any benefit from getting a two row 120mm rad. Thermochill 120.1 (with or without a shroud) or a Black Ice GTX 120, which is a bit cheaper, or not bother at all as it won't make much difference?
Seems to me that it should have better cooling?
Thanks in advance.
Thanks in advance.
