I just changed my main system from ATX form to mITX with a Asus ROG z97 board and the 'supreme FX' is not very supreme at all, from the marketing I expected that it would be similar to one of the full size Asus sound cards
( I have the essence STX )
So I probably need something that I can connect via usb that will be significantly better than the realtek chip, however that seems to defeat the purpose of having a highly transportable pc ....
I do have extra room in the case though which could fit something about the size of a standard hard drive and there are cable holes at the back that could passthrough several thin cables outside of the case, so I might be able to have an internal external sound device if that makes sense
I dont really know anything about audio things though, I always just buy the various asus PCI slot sound cards
I dont need to connect to a complicated audio system, just 2.0 speakers or headphones.
What I find odd though is my PSVita and MSI GX740 laptop have very good
audio quality compared to this motherboard and they dont exactly have 4 inch long shielded sound cards
