Need some spec help please.....
21 Jan 2005
Manchester
...going to be used in an office for DTP, video, web and animation work, min requirements are..
Quad core
4 gb mem
8800 gtx overkill?
24 inch screen
raid and external storage
I might slightly overclock but would have to be well within limits as this is a mission critical machine.
Thanks in advance, would like to order today if I can.
As a mission critical machine imo I wouldnt overclock it.
Its a good set up, what RAM are you thinking of buying?
Well I overclocked my 6600 server in the office to 3.12 but it is watercooled, I will overclock but not by much, re the ram I was thinking geil 2 x 2gb 6400
Ok, brought the price down by getting a smaller monitor and graphics card. Thoughts and suggestions anyone?
Samsung SM-226BW 22" Widescreen LCD Monitor - Glossy Black £214.99
Microsoft Windows Vista Ultimate 32-Bit Edition DVD - OEM - 1Pk (66R-00765) £99.99
Creative Gigaworks T20 2.0 Speaker System - Retail £53.99
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) 74.99
Samsung SpinPoint T HD401LJ 400GB SATA-II 16MB Cache - OEM x 2 £95.98
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £224.99
Antec Nine Hundred Ultimate Gaming Case £54.99
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM £15.50
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard £104.99
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB) - Retail £199.99
Thermalright Ultra-120 Extreme (Socket AM2/LGA775) Heatsink £31.99
Western Digital MyBook Premium ES 500GB eSATA 3Gbps / USB 2.0 External Hard Drive (WDG1SU5000E) £81.99
£1,254.38 +vat
buy cheaper speakers which will save you more money: and have a look at my thread and the suggestions that poeple have made, I'm in the same boat as you but also want a bit of gaming, also ive decided to get further 2gb later on:
http://forums.overclockers.co.uk/showthread.php?t=17755262
I hope that might give you an idea. I also admit I dont think the mobo is good for overclocking though so my thread might not be that much help to you.
stickroad said:
Loose the PSU, you dont need that much power.
This will do you fine:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-CS&groupid=701&catid=123&subcat=823
And what about Memory?
Well as its only £15 more I thought it would give me more upgrade options.
Memory I was thinking of this
OCZ 4GB (2x2048) Vista Performance Gold DDR2 PC2-6400 Dual Channel memory Plus Gold XTC Heatspreader
Also Ive sacked the stacker and swapped for an Antec 900 which has shaved £60 off the price
Thats fine for the Memory.
Unless your planning going SLI which is poo anyway :p . The Corsair 620 model will be fine for upgrades in the future.
