Bear with me for a moment please
All week I have been debating what watercooling option I should go for, this is the last deciding factor before I order my parts (new build).
I have no problems building pcs's but have always done so with aftermarket heatsink and fans.
The trouble I am having deciding was with these options:
- All In One Liquid Cooler such as the Corsair H100i
- OcUK Tech Labs 240mm Fathom
- Custom Watercooling
The case will be the Corsair 540, I will be overclocking the i7-4770k, my budget for cooling will be as close to £200 as possible (I have not considered GPU watercooling yet), I want the order doing tomorrow so today I need to get as much advice and suggestions as possible please.
I like the idea of custom watercooling as I would imagine better cooling performance, plus I really love how they look especially with the clear tubing and stuff
I have no idea what parts I would need though and understandably leaking is my biggest concern.
I started picking out these parts but I have no idea if they are good/compatible and what else I need.
Radiator:
Hardware Labs Black ICE Radiator GT Stealth 240
CPU Block:
Aqua Computer Cuplex Kryos Delrin for 775 / 1155 / 1150 / 1156 / 1366 - G1/4"
Reservoir:
Bitspower Z-Multi 150mm Water Tank - Ice Red
This is all I have so far (IF I DECIDED CUSTOM).
I think I would need a pump and other things like tubing but I am lost already. I am sure once I do my first it will get easier but right now I am absolutely lost!
I would greatly appreciate some advice from the watercooling gods
Thanks!!
Radiator:
CPU Block:
Reservoir:
Thanks!!
