need some tech help pls
9 Jun 2011
UK
hi all i hope i can pick some brains from you tech geeks out there.
problem is my desktop pc at any time randomly keeps shutting down and then reboots into desktop without any warning messages.
my set up is :asus rog strix z490 f gaming motherboard,intel i9 10850k,corsair ddr4 16gig@3200,two samsung ssd pro's,gigabyte rtx 2070 super windforce ,corsair hx1000 psu, windows 10 pro.
things done:
replace psu to corsair hx1000
replace each usb's ie keyboard,mice etc and replace them back one at a time.
cpu stress test,graghics card bench test,re-install windows,replaced each ram sticks back one at time,there is plenty of cooling in the case. there is no warning lights showing on motherboard. bias is on default settings.ram is set on xmp1.
not sure if i have missed anything but the problem is still there just random at any time shuts down and reboots back into windows. any help would be gratefull
Drop memory to JEDEC defaults, try one DIMM at time...
Also check Event Viewer and Reliability history for anything time marked close to reboots.
we done all the possible checks that we can think off cpu/ram stress test with one stick in at a time,graphics card test and cpu graphics test,taken out all usb leads keyboard,mice etc, discornect all other ssd drives just left c drive ,what i can't see reports not showing anything motherboard on default settings ..am thinking it could be a problem with the motherboard somewhere ?? any other help yous can think off
