- 18 Nov 2007
Hey guys
i need some help with overclocking my machine
Specs
Q6600 (b3) stepping, 2.4ghz (stock) (((Stock cooler))) Currently @ 2.7 ghz
4 Gb of ram , 2x ddr800 kingston and 2x ddr800 Pny (Dual Channeled)
Asus p5b (needs updating)
Evga 9800 gtx
650 w coolermaster
As you can see i have already clocked the machine at 2.7ghz and am running stable with cores at around 44,42,41,43 idle 49,48,50,46 under load. all i have done is raided the FSB up to 299.
My vcore and most of the other options are set to auto such as the ram timing frequencies which i have no idea of. my problem is that i am trying to acheive 3.0ghz on the stock intel cooler is this possible as when i have tried clocking it to that speed before it crashes on boot up and i have to remove power cabels and reset. Im pretty sure it is another setting causing this possibly the ram? or maybe i have just hit my limit
If anyone could kindly help on the situation it would be more than appreciated
Specs
Evga 9800 gtx
650 w coolermaster
