- 5 Oct 2009
- Dorset
Hi
I put together my first rig in March 2007 ready for Crysis but its been unplayable for me to date so not actualy played it yet... frustrating but I want to play it at 2560 x 1600 rezzy on my 30" panel and it can't cope so I just put it off. Kinda hoped a patch would come in and it would be OK lol but that never happened. Anyway, one of my GTX8800's went bang so I am RMAing it. But it's got me thinking, if I upgrade my GPU's or one of them will I be able to play Crysis how I want to, and if so how long will this PC last me in terms of new titles? or am I better off starting again and if so what spec should I be looking at get it right on this panel. I just didn't buy the panel so I could watch it in low rezzy....
Im guessing my CPU isn't up to it also. So same questions regfarding upgrade apply to that too. Or am I better off saving the cash from upgrading and buying a new rig altogether.
Im sure you get lots of these posts and I apologise for that in advance but I really am torn between trying to fix this one up, which I don't know if it is a lost cause, and buying a new rig. Any thoughts?
My gear
Abit IN9 32X-MAX WiFi nforce 680 mobo
2 x GTX8800s 750mb GPU's in Sli...one gone pop
E6600 CPU
4gb Geil PC6400C4800MHz DDR2
Dell 3007wfp panel
Vista 64bit
Thanks for your consideration!
My gear
E6600 CPU
Dell 3007wfp panel
Vista 64bit
