I'm totally new to water cooling and need some advice. The closest I've ever got is a H50.
I was thinking about getting one of these kits:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-117-EK&groupid=962&catid=1532&subcat=
But how big is the performance gap between each one?
How much better are the HF than the LT?
How much better is a 360cm radiator than a 240cm radiator?
Is the coolant included good enough, or would you recommend a different one?
And it says you need 1L of distilled water. Isn't that what the coolant is for?
