Need something to stack laptops
Permabanned
7 Nov 2002
Over there
Hi
Im looking for a cheapish (around 30 quid?) unit that is basially something I can stack laptops on. I have attached a couple of pics so you know what I mean.
I need access to the front back and sides for different ports. One of the laptops is a Dell 17 inch that I would idealy like to be the one sitting on the top, and the second is a Macbook Pro 15". I need the computers to sit flush i.e. be firm and not balancing or underhanging if you know what I mean.
Anyone know where I can pick this up? Something metal (silver) and lightweight is best. A Griffin iCurve is no good for me.
Cheers.
i personally dont know, do u need to use both at once? cos your drawings look like its just the top one. U mite find something like a small glass Tv stand would be suitable or somethign similar...
I've seen little metal cupboards like laptop docking stations where you can store loads, but i bet they aren't cheap. No idea where you would get them from. Perhaps office supply shops or catalogues?
You might find a metal paper storage system would work?
