- 6 Dec 2012
Hello all,
I'm about 5 years out of date in terms of what's out there now so if anyone can help me I'd be immensely grateful!!!
I intend to build an XBMC HTPC in the new year for my living room. I already run a Revo 3700 in my bedroom but wanted to make a more powerful offering for my main TV.
My requirements are as follows:
> 64gb SSD which I assume will be more than enough as I'll be keeping everything on a NAS?
> Ability to playback 3D content when I eventually invest in a 3DTV sometime next year.
> As quiet as possible air cooling
> Blu-ray drive
> XBMC compatible Freeview HD Tuner (can be single as I don't record TV anyway)
> Logitech Harmony Remote - Think I may hide the case in a new TV bench at some point so will have to invest the IR extender add ons.
> Silverstone Lascala case (not decided which model yet but I will allow about £120 for it) or another if anyone can suggest any others of minimalist HTPC design.
Other notes & questions
> This system won't be used for gaming (may do in future, but for now definitely not)
> Would my 5 year old modular ~500 watt Tagan PSU be sufficient/compatible with this? If so, that can be left out of the budget for now.
> Is it worth getting an additional sound card these days? This will be used in a proper separates sound system so audio is definitely a very important factor for me.
What's the minimum amount I'd likely need for this build?
Many thanks in advance
> Blu-ray drive
