need specific psu
8 Oct 2014
I'm looking for a modular psu upgrade for a in win 904.
Min power 650
Max length 160mm to fit in the space
And i need it to be modular
Any suggestions?
Thanks
Hi and welcome to the forums. :)
Most psu's under 750w are 150mm long so there is a huge choice. What is the budget for a psu and what components will it be powering? It is unlikely that you will need 650w. It's a bit of a poor size really as it's too much for a single card setup and not enough for a dual card setup. Many people over estimate the size of the psu they actually need. The pc in my siggy only pulls a max of 420w at the wall while gaming.
Thanks for the response. I'm using a Amd fx 8350 and a nvidia 690. Budget wise anything under £100 would be nice but I can stretch. Just has to be modular.
In that case 650w may be enough but i would suggest a 750w psu to give some extra headroom, especially if that 8350 is overclocked. Her are a couple to consider:-
EVGA Supernova G2 750w Superflower built unit based on theit Leadex Gold platform but with a awesome 10 year warranty.
Superflower Leadex Gold 750w Basically the same as the above but with a couple of differences such as Led's and the fan. Unfortunately out of stock at the moment.
