Need specs for a full build (3x Price ranges)
Caporegime
1 Oct 2004
Redcar
Hi there,
I'm looking to invest in a PC that's primarily for 3D rendering, video rendering and such, but will also be used for gaming.
I'd like a lot of RAM obviously but also as much bang for my buck as possible.
I also need a monitor as the one I have is now screenburned and beyond use for accurate graphic work. I currently use a 24" monitor and wouldn't want to go below that, an HDMI port would be a bonus.
I need Windows, mouse and keyboard. I don't want rubbish, but also don't buy into the 'gaming' peripheral rubbish either. I'd also like a nice case that has easy access to audio and USB ports on the front (preferably at the top), I don't mind a cover as long as the USB and Audio ports aren't hidden behind it.)
As I say, I need everything for a build.
The price ranges are as close to £1400, £1700 and £1900.
Thank you.
That looks like a great build RJC, wouldn't it require extra fans as well though for cooling? The CPU is covered, and I believe the GPU has an integrated cooler, but maybe chuck some 120mm fans with it as well for NokkenWud?
