Hey OcUkers, I'm about to build my first home server and will use it primarily as storage for large files like music, films, backups etc., it will connect to the PC in my room via my router.
My budget is max. £170 (cheap as chips I know!) and the components don't need to be high tech as the server will just sit there and store/receive/backup files.
These are my requirements>>>
Need to buy:
*Motherboard - ATX with 3xPCI/PCI-e slots if possible; inbuilt audio; >3USB ports; RAID1; SATA connectors (an IDE if possible)
*CPU, heatsink + fan
*RAM - min. 512mb DDRx
*Case (Tower) - needs to hold at least 6-8 internal 3.5" hard disks
*PSU - >400w, I think, due to so many hard disks, with at least 6-8 molex connectors
*Graphics/Network card - might not need this if it's inbuilt on the mobo (wireless not necessary)
*Fans - I'm not sure which size or how many
*PCI/PCI-e Connector card for IDE drives - I have at least 4 PATA HDs that would need connecting to the mobo
What I DON'T need:
*Hard disks
*Monitor
*Mouse/keyboard
*CD-ROM/DVD-ROM or any other external drives
*Operating System (will most probably be using windows home server)
Any help would be great, thanks!
Need to buy:
What I DON'T need:
*Hard disks
*Monitor
*Mouse/keyboard
