Hi all,
Just finished a new WC build and I would like to move the fans from the motherboard to a fan controller.
I have a mixture of 3-pin (traditional) and 4-pin PWM fans, below are the number of fans and where:
2x 140mm 3-pin fans at front of case
1x 140mm 3-pin fan at rear of case
2x 120mm 4-pin fans supporting bottom rad.
3x 120mm 4-pin fans supporting top rad.
The 140mm fans are: Corsair AF140 Quiet Series Low Noise High Airflow 3 pin
The 120mm fans are: Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin
So all in all, I'm looking to control 4 sets of fans, so I was looking at the Lamptron FC5 or FC6, the problem as I mentioned I have a mix of 3-pina nd 4-pin, will a traditional fan controller work with the PWM fans?
And if so, whats the main difference betwen the Lamptron FC5 or FC6? I've heard a mixture of issues with the FC5 not being able to control single fans etc on their headers, whereas the FC5v3 looks nice (and expensive) the FC6 not heard of it yet.
So anyone have any suggestions please?
Thanks,
Thanks,
