Need suggestions for first build - i7 920
6 Jul 2009
Good morning everyone, this is my first post on the forums however I visited the shop and forums quite often. I see there are many wise people here so I want to make sure I have a good build, the title already says it: my first build. Will use the PC for gaming, editing software (photoshop, after fx etc.). Anyways, here is a screenshot of my basket.
Sub Total : £844.50
Shipping : £10.00
VAT : £128.18
Total : £982.68
The case is NZXT Zero 2, but I will buy that from a different site since OcUK does not sell NZXT cases, the PSU I will buy it from a Dutch website because in the UK they use different power cords. It is a Be Quiet 850w modular PSU.
I will replace the graphics card with either a HD5xxx card or GTX300, when they come out. So it's a temporary card.
Also, I am buying the overclocked bundle because I am only 14. Not really seeing myself overclocking. I'd rather to be save and buy a bundle that guarantees you the overclocking level you want, so please do not replace it with seperate components. I do realize that it's cheaper though.
Any suggestions?
If the graphics card is just a temporary solution, get this one instead and you will be able to play games properly before the DX11 cards come out. Sell it later if you want.
Instead of the Velociraptor, you should probably be looking at an ssd like this one for putting your OS on. It may only be 60GB, but its considerably faster than the WD and 60GB should be enough for an OS drive.
Looks good, will replace. Thanks for the suggestion
Edit: I'm pretty this is a dumb question, but my case doesn't have a 2,5'' drive bay?
DRIVE BAYS 13 DRIVE BAYS
5 EXTERNAL 5.25" DRIVE BAYS
2 EXTERNAL 3.5" DRIVE BAYS
6 INTERNAL 3.5" DRIVE BAYS
Screwless Rail Design
I'm not sure how the Agility series holds up. Not sure if you know, but there has been immense fuss over SSD's and poor random write performance, so you need to be careful which one you buy. At the top of the list right now are the Intel drives and the OCZ Vertex drives. I believe there are a few others with Samsung controllers that are quite good, but those two are still at the top.
Again, not sure about the Agility.
Have a read of these SSD articles here: http://www.anandtech.com/storage/ there is another one due soon which will include newer drives etc, so keep an eye out for it.
Or
Assumed you might need an operating system.
Will get Vertex 60GB then, but I am ordering the components two weeks later, maybe more news about SSD's at the end of July.
I would recommend keeping the optical drive as the original Sony you had. It's the fastest, best writing drive at the moment.
850w should be more than enough for high-end SLI, but the cards need to be the same.
Is overclocking that important to you? Because if you get an i7 at 2.66ghz, you can then spend more on better parts which would probably equal the same price as you have specified.
Okay so I found a pretty good guide on overclocking the i7 920 by Gigabyte. Looks pretty easy, means I will try to overclock it myself. Added a nice soundcard and cardreader.
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail + World In Conflict PC Game £208.99
(£181.73) £208.99
(£181.73)
OCZ Vertex Series 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX60G) OCZ Vertex Series 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX60G) £200.99
(£174.77) £200.99
(£174.77)
Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £143.99
(£125.21) £143.99
(£125.21)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) £79.99
(£69.56) £79.99
(£69.56)
Asus Xonar D2 7.1 PCI Sound Card (90-YAA021-1UAN00) Asus Xonar D2 7.1 PCI Sound Card (90-YAA021-1UAN00) £76.99
(£66.95) £76.99
(£66.95)
Powercolor ATI Radeon HD 4850 PCS 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail Powercolor ATI Radeon HD 4850 PCS 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail £71.99
(£62.60) £71.99
(£62.60)
Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM (WD1001FALS) Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM (WD1001FALS) £68.99
(£59.99) £68.99
(£59.99)
Razer Copperhead Tempest Blue 2000dpi High Precision Gaming Mouse - Retail Razer Copperhead Tempest Blue 2000dpi High Precision Gaming Mouse - Retail £37.98
(£33.03) £37.98
(£33.03)
Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366) Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366) £33.34
(£28.99) £33.34
(£28.99)
Microsoft Digital Media Keyboard 3000 (J93-00006) Microsoft Digital Media Keyboard 3000 (J93-00006) £20.99
(£18.25) £20.99
(£18.25)
Sony Optiarc AD-7241S 24x DVD±RW SATA-II Lightscribe Optical Drive (Black) - OEM Sony Optiarc AD-7241S 24x DVD±RW SATA-II Lightscribe Optical Drive (Black) - OEM £18.99
(£16.51) £18.99
(£16.51)
Akasa Internal Smart 8 Port Card Reader (AK-ICR-05) Akasa Internal Smart 8 Port Card Reader (AK-ICR-05) £16.09
(£13.99) £16.09
(£13.99)
OcUK Value 2.5" to 3.5" Hard Drive Adapter OcUK Value 2.5" to 3.5" Hard Drive Adapter £5.99
(£5.21) £5.99
(£5.21)
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin £5.74
(£4.99) £11.48
(£9.98)
