Need suggestions on a PSU
22 May 2014
Hey guys,
I am in the process of building a Mini-ITX gaming PC and it turns out that the PSU I had planned on buying is out of stock pretty much everywhere I look. I was interested in this one:
https://www.overclockers.co.uk/showproduct.php?prodid=CA-011-SF
But I can't seem to find it anywhere, and don't really know enough about PSUs to find another similar one.
The components I have so far:
Corsair CC-9011061-WW 380T Graphite Series Windowed Mini ITX Portable Gaming Case with LED Fans for PC - White
MSI Z97I Gaming ACK Intel Z97 (Socket 1150) DDR3 Mini ITX Motherboard
Intel Core i7 i7-4790K CPU (Quad Core 4GHz, Socket H3 LGA-1150)
WD 2 TB 3.5-inch Internal Hard Drive - Black
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8)
Raijintek Triton Core Edition AIO Water Cooling Solution
MSI NVIDIA GTX 970 Gaming Twin Frozr HDMI DVI-I DP Graphics Card (4GB, PCI Express, DDR5, 256 Bit)
I need a PSU that will fulfill all of the power needs of these components (including some overclocking), is efficient and does not produce much heat, and is £80 or less. It also needs to be less than 160mm in length in order to fit the 380t case.
Any and all help is welcome :)
Hi and welcome to the forums.:)
A quality 550w psu would be more than enough for your pc even with overclocking. I am suggesting the 650w version of the EVGA Supernova GS because it's cheaper than the 550w version until next Wednesday morning due to being on offer. It's a quality, Gold rated, Fully modular unit built by Seasonic and has a 5 year warranty. It's also only 150x150x86mm as well. There is a review here.
YOUR BASKET
1 x EVGA Supernova GS 650W '80 Plus Gold' Modular Power Supply £69.95
