DizzyEgg said:
so to improve fps i need to swap my lame celeron for a p4 2.6 or something?
I dont mind doing this because when I go uni next year I can take it out and put it into a file server I am thinking of.
When I do that my gfx card will be holding me back tho, what fps do you think I would be getting with a p4?
google some benchmarks of a Pentium 4 (at the speed you want), 9 times out of 10 they'll be using Half Life 2 in the benchmarks so you can compare it to that (as CS:S using the Source engine as does HL2... of course).
only thing then is to add on or take off a few FPS depending on what graphics card they use during the benchmark.
before rushing off to an auction site for a 6600, check out the Members Market on here... i've seen a couple of AGP 6600 models going on there in recent days. Brand new your looking at around £85 - £100 or so though i think.
what kinda cash are you looking to spend on it?
overclockers have got a 3GHz P4 Prescott for £100
here
still may be out of your price range if your looking for a little quick fix.
little thing for you:
Upgrade : Result
CPU : Boost in frame rates
Ram (to 1GB?) : load times faster - steadier FPS (not quicker, just steadier)
GFX : Good boost if buying a good model, but wont do much without a new CPU
the problem with upgrading just one part of the machine, is that the others hold it back. there's no point having a £200 or even £100 graphics card if the processor can't keep up with it. same goes the other way around, you could be running an FX57, 2GB of ram and using a old Geforce MX card... and of course it would be terrible because the graphics card is out dated.
