Need to Buy/Borrow Yamada Remote
27 Oct 2002
I was just wondering if anyone has a faulty/retired yamada divx player lying around and could spare the remote for a couple of days. I have a problem with mine and would really like to get hold of a remote for the day to learn the codes. Thanks
you may be in luck :)
i just bought a one-for-all 4 in 1 remote
it learned the remote settings for my yamada dvx6600 with the search function and ~18 presses of the power off button (i.e you set the one for all into search mode and cycle thru all the codes till finding one that switches off your player)
hope this helps
