hey there, ive just been trying to figure out a decent set up for a new pc. I have a budget of roughly £500 but can go slightly above if needed. So far i have this
Coolermaster Elite 330 Midi Tower Case
AMD Phenom II X2 Dual Core 550 3.10GHz Black Edition (Socket AM3)
Asus M4A78T-E AMD 790GX (Socket AM3) PCI-Express DDR3 Motherboard
OCZ Platinum AM3 4GB (2x2GB) DDR3 PC3
Asus ATI Radeon HD 4850 512MB GDDR3
OCZ ModXStream Pro 400w Silent SLI Ready ATX2 Modular Power Supply
BenQ 22" G2220HD monitor
Sunbeam Core Contact Freezer CPU Cooler (Socket 754/939/940/AM2/AM3/LGA775)
It comes to roughly £550. First off i just want to check the compatibility of the cpu and the motherboard. This is the first time ive made a computer and im not sure if this is ok or not, but i saw that under the specs for the motherboard there was no sign of the pheonom IIx2 for supported cpu type. So im under the assumption that this is not compatible even though it is an am3 type cpu. I heard the 790gx chipset was good as well as the southbridge but was wondering if there is anything out there that is good/better for the same/less amount of money. Can anyone give me any suggestions please? - also can anyone say whether or not the cpu will work on this board or should i think about a different one?
Also can anyone give me suggestions on any of the hardware.... problems, improvements etc?
many many thanks to any advice
p.s already got a harddrive
