Need to cut sections from MP3s for project
31 Oct 2002
Has anyone here ever used a program to take a section out of an MP3 to make a smaller clip? I need to do this for a project - got 2 MP3s and need some clips out of them. Had a quick look but seemed loads of programs but most you can't save with - I wanted something free or shareware rather than free trial - don't think I'll need it after this.
Creative do software, so if you have a sound card by them then check the site.
KaHn
nero has wave editor which allows you to import mp3s, and save them as well depending on your license.
Otherwise save as WAV and use a free Wav -> MP3 tool
cool edit was what I used to use, great app, sound forge can do same job, maybe there's a trial version kicking about. there's also a little small app less than 1MB, simply called mp3splitter (i've not used it though, but i gave it to someone and they found it worked a treat, and simple to use).
theres a really easy to use program called MP3Trim. cant remember where i downloaded it from, buts freeware and really easy to use
BruceLee said:
MP3directcut is an app that does just that. Audacity is a bit complicated for a simple slice and dice.
Its freeware too.
I've used MP3directcut too.... quite easy to use, and I've been happy with it
Pax
I'm trying to cut part of an MP3 and export it as a as .mp3. However I am having trouble doing this in both Audacity and MP3Directcut. Anyone provide any hints?
Edit: I have created a Audio track in Audacity by clicking the record button and then the stop, but I am unable to export/save this?
Thanks
Pdog
Thanks
Pdog
Goto File > Export As Mp3.. and save it as whatever you want. You need to have LAME for this to work.
Cheers Ddave, this has now been done. Now I have another issue. The MP3 original was in stereo, however when I have recorded the section I want it does it Mono and sounds crap, how can I then get this into Stereo?
Audacity is very good indeed, and allows all sorts of effects. I use it to convert bits of songs to use as ringtones on my mobile, it allows fades in and out so there are no sharp cutoffs etc etc
