Need to DSR but used Gold Ticket code!
1 May 2013
M28
Anyone help
Need to return a card, was advertised as voltage unlocked but, the volts are locked to 1.25 max, even though the slider will go higher the volts remain the same.
But in my haste have used the free game code.
Yes the TOP is voltage locked. The Platinum isn't. With regards the code you will have to ask the shop. I guess they will either say you can't return it or you will have to buy the gold bundle which is advertised at £89.99.
EDIT: Ignore me I misread. You have plat.
gpu tweak and also hwinfo64
also the gold reward does not have a £ value, it is not for sale, where did you get £89.99 from? on the invoice it has a £0.00 amount.
You should be able to sort out the voltage thing. But if you want to DSR it you'll have to post in the CS forum and ask. They might take it back even though you've used the code, they might not be able to.
seems a bit dodgy might have to narc to AMD since these are part of a promotional deal and should not be for resale.
ocuk is AMD's main retailer in the UK, there won't be anything dodgy going on.
But saying things like this won't do you any favours...
I suspect the selling of it is to allow for exactly these situations where someone wants to return the card after using the games.
Anyone help
1.255v is usually what most sane people put this baby and they hit ~1275 core.
Either way someone else got the same card yesterday and plug it straight away to 1.3v without issue. Maybe you need to ask him how to do it? mjenabi2 is his name.
The Platinum is not voltage locked, you can even adjust the voltage by using buttons on the card. It's advertised correctly.
The Golden Ticket cannot be purchased separately, you can only obtain it by buying a qualifying product from us.
