- 11 May 2006
I'm going to move into a newly converted loft (2nd floor) soon but my main telephone socket is in my front room (ground floor). Initially I was planning to get a telephone socket extension up to the loft and connect my router from there, but from experience this has a negative impact on ADSL sync speeds.
So, instead what I'm thinking about doing now is to have some sort of ethernet cable running from my front room to the loft, with both ends terminated by a ethernet socket - essentially a ethernet extension. This way I can just leave my router downstairs in the front room, get maximum sync speeds, connect by LAN and not have to use a crappy wireless card.
As you've probably already guessed though, I'm not entirely sure what I need in order to pull this off, so I would really appreciate some advice on what components I need, e.g. the types of cables, sockets, etc.
Also, although I only have a 100mbps capable router, for future proofing I would prefer an extension that is capable of handling 1gbps but still backward compatible for a 100mbps router.
Thanks!
Thanks!
