Need to find some 32 bit dependencies for Ubuntu
Commissario
16 Oct 2002
In the radio shack
Hi :)
I've just installed Ubuntu 7.10 and I want to get the Eve Online client running on it - However I've installed the x64 version and for the client to run it needs the following 32 bit dependencies..
* ibc6 (>= 2.2.4-4)
* xlibmesa3 | libgl1
* python (>= 2.4)
* python2.4-dbus
* python-gtk2 (>= 2.6)
* python-glade2, wget
(list from here)
I've had a hunt but being a bit new to Linux, I'm having problems here. Can anyone help me using simple terms as to where and how I can find/install these?
Thanks.
Code:
dpkg -s python python2.4-dbus python-gtk2 python-glade2 wget libc6 | egrep "not installed|Package|Version"
Not sure what package xlibmesa3 is in though..
I think ibc6 is in libc6 package but not 100%.
As for installing the packages just sudo apt-get install package1 package2 etc... When you know what packages the libraries you require are in.
Hmm, the trouble is that if I do that, it tries to install the 64 bit versions which I've already got, and the client needs the 32 bit ones. Tricky.
in /etc/apt/sources.list is x64 specified anywhere for any of the repositories? if it is, you could try swapping those for the x84 repos and doing an apt-get update before trying to install the packages you need.
Worth a shot anyway, and as I don't run any 64bit stuff I cant test out this theory for sure :)
Tried this yet?
Code:
sudo apt-get install ia32-libs
Aye..
Code:
Reading package lists... Done
Building dependency tree
Reading state information... Done
ia32-libs is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
And it's working - Nothing I tried is different from the previous attempt where I got loads of errors about the dependencies, but now it's running, yay!
