Need to get rid of: http://trialtry.cn/1/locator.php?q=
28 Sep 2004
This seems to be putting itself infront of every URL on a works computer and stopping the URL from working; usually from a google search.
We're using IE7, and a run of spybot didn't fix anything. Any ideas?
check your reg settings. It looks like something is adding that part to every URL that is clicked on.
"HKEY_LOCAL_MACHINE\SOFTWARE\Classes\htmlfile\shell\open" (should be \shell\open but for some reason it's not displaying right...)
should look either like this
default = Open in S&ame Windows
or
default = "C:\Progra~1\Intern~1\iexplorer.exe" -nohome
You'll know if it's wrong as the default part will have the url that you mentioned above in it.
Hope it helps.
