Need to install new OS
12 Jul 2010
ok i'm buying this laptop after months of deciding.
i saw 70% of all 4 star ratings was because it's packed with junksoftware.
they all recommended installing brand new OS.
firstly can i use the OS key which comes with it. it's a win 7 pro key so if i borrow my friends DVD, will the key work?
otherwise i found somewhere else i can just buy windows 7 prof key so then i can borrow my friends disk & it'll work like that. will the key work for all versions of windows 7?
Depending on brand of laptop you may be able to make a custom Windows DVD that won't require product key entry or activating.
The big OEM's use System Locked Preinstallation, that require a few files being added to your custom DVD of Windows 7, but varies depending on who the OEM is.
It was pretty interesting doing it for Windows XP, but not read up about it for Windows 7. Check My Digital Life forum instructions and tools.
It is also depends on what are the specs of your laptop because Operating Software has it's own system requirement. If you have a limited memory then you should have a light software so that it wont lag when ever you use it.
if the laptop has win7 on it, then you can just install the correct version of win7 from dvd/flash memory and use the product key on the bottom of the laptop to activate.
it may require you to activate by phone if the product key is oem tied but it will allow you to install with it. (you won't need to buy another licence)
dead simple really,
can be well worth doing but not always necessary, usually just to get rid of all the hidden partitions etc so you maximise your disk space, just make sure you have downloaded the drivers and any software you may find useful, some of the software may be tied to the installation as oem so you cant download and reinstall unless you pay for a license,
check what reinstall / hidden partitions the laptop has as you can always go back to that, depending on the manufacturer, there is usually one the F keys you can press in dos to do this. alternatively, you can create a back-up disk
alternative, you can just uninstall the bloat-ware using windows uninstall. this would be my preference and if it is a dell / acer / hp home laptop etc then all the support software and security suites etc which tend to be bloatware uninstalls really easily, just run cccleaner after and do a c drive and registry clean and jobs a goodun.
the big one for me is getting rid of macafee/norton suites in favour of microsoft security essentials or other less resource hogging anti virus. you can simply download their removal respective tools and follow the instructions.
You'll never ever remove all of the bloatware through WARP and there will always be registry entries which aren't removed. Then, it becomes laggy and buggy.
My advice, for anyone, even those who buy a new laptop, is to fresh install Win7. Also, you don't need a licence key to install Windows 7, only to activate. There is no bloatware I can think of from any major brand worth having over a completely clean OS install.
definitely...
i love my laptop as i know it's my own now, theres no god forsaken asus programmes on here only my programmes.
fast boots & good preformance all around :D
saying that i got an SSD for my main pc, my laptop does a very good job keeping up to it in terms of boots and opening programme speeds.
You can definitely reuse the key on the bottom (activations are linked to hardware configuration). You will need to call to use the automated system, but it's pretty easy. Make sure you use the same edition of Windows
