need to know..
is it worth calling overclockers uk i have done so much stuff and it just annoying its a small problem but what is always there, everytime i startup 3 different games slow response times on skype saying that i still have a unread message when i have read it, dragging windows applications around and seeing a white blur behind it. just little things but it shouldnt be like this
does it go away if you lower the ram speed?
your not losing much if any performance by running at 1600mhz
EDIT: you can also test with more imc voltage but not sure what its called on asus z87
idk either on asus z87
it should say something like system memory multiplier,your manual should tell you
then you'll see a drop down list of all the ram speeds and you pick which one you want
