Need to lock down remote access to my Cisco, I dont want to use telnet but dont have SSH :(
1 Dec 2004
S.Wales
As above really, at home I have
Netgear --- Cisco ----LAN1 / LAN2
Now at the moment to manage remotely I have telnet enabled with a strong password, however as most of you are aware telnet traffic is not encrypted and quite a security threat.
What I have done for the moment is open up telnet ports from my IP range in work so I can get to it from there, without having anyone else being able to jump in.
With regards to SSH, iv read up on a few sites and even tried enabling SSH but im not sure if my router is capable of it, however there are documents I found on the web contradicing what I read saying yes I can be done but its an earlier version.
Here is my show version output
Code:
morandarouter1>show version
Cisco Internetwork Operating System Software
IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(22), RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 24-Jan-07 15:39 by ccai
Image text-base: 0x8000816C, data-base: 0x80B99150
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y7-M), Version 12.3(22), RELEASE SOFTWARE (fc2)
morandarouter1 uptime is 2 days, 22 hours, 44 minutes
System returned to ROM by power-on
System restarted at 23:32:13 UTC Wed Aug 19 2009
System image file is "flash:y"
cisco 1720 (MPC860T) processor (revision 0x601) with 27656K/5112K bytes of memory.
Processor board ID JAD05350SP6 (3674387206), with hardware revision 0000
MPC860T processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
Any help appriciated, I would rather be able to use SSH
Have you tried connecting with an SSH client (putty) to port 22? Usually if you enable remote console access both telnet and SSH are enabled by default.
It wont let me in over the SSH ports no, iv tried following the guide and using the cryptokey command which sets up the SSH but its not working :(
When I enabled telnet I used the commands
ExampleName(config)#line vty 0 4
ExampleName(config-line)#login
ExampleName(config-line)#password (enter password)
ExampleName(config)#ctrl-z
Have you tried using the command 'transport input ssh'?
Sounds like you've already created the keys using the 'crypto key generate rsa' command followed by the say 1024 bit keys.
*You'll need 'transport input all' if you still want to be able to use telnet.
So for example:
ROUTER>en
ROUTER#conf t
ROUTER(config)#hostname Bob
BOB(config)#ip domain name Bob.cisco
BOB(config)#crypto key generate rsa
How many bits in the modulus [512]: 1024
Generating keys etc [OK]
Bob(config)#line vty 0 4 (or 0 15 depending on model)
Bob(config-line)#password cisco
Bob(config-line)#login
Bob(config-line)#transport input ssh
That's just an example.
*You'll need 'transport input SSH telnet' if you still want to be able to use telnet.
I got an error when I tried to create the crypto key, cant remember what it was as it was a few weeks ago since I attempted it but ill try it again and will post back with the error it gives me
To create the keys the hostname needs to be different from 'ROUTER' and you need to have joined a domain.
Let me know how you get on.
Cheers
the hostname was changed when I configured it first off, not sure if iv joined a domain though?
Dont think its going to work :( I keep getting the below error when trying to generate a key, everythings been configured as it should be.
Code:
morandarouter1#show ip ssh
% Invalid input detected at '^' marker.
morandarouter1#crypto key generate rsa
morandarouter1#morandarouter1>show ip ssh
Oh well,
I will just have to use telnet for now and just have my firewall blocking telnet ports until I need to use it, then log on to my router and open the ports but lock it down to the specific IP address that im using at the time.
When im finished I will close the ports on the firewall.
The router wouldn't support VPN termination without a crypto image, only VPN pass through to something like a win2k3 server which he has - it's just broken
Server is fixed and I have got an SSH server running on it if I need to use it as a backup method. However now I will be getting the IOS image I dont really need it.
Will let you know when I get the new image on the Cisco.
