Hi all
I need to make a complicated website and not sure which language to use for backend.
I can program C++ and use this mainly for programming probabilistic models rather than applications.
Initially I thought to save time that i should program the backend in C++ and the front end in JavaScript, HTML and CSS. But it would seem that using C++ to program backend could be problematic and difficult. If I had ample time would attempt it but I'm pressed for time currently.
So I am thinking of learning C# & ASP.net Core and using this for backend and JavaScript for front end. I used c# in 2012 in limited capacity but I would have to relearn it.
I also believe its possible to use both JavaScript for back and front end. I have little webpage development experience so not sure what language to use and what might be best.
any advice from someone with experience would be appreciated. Ideally least difficult implementation as I will spend appx 6 months on learning the relevant languages (c#, JavaScript, Html, CSS etc) and few months to actually programming the site. I have given myself appx to end of year to complete this.
I also need to make banners, backgrounds and all artwork required. I assume most of this can be done in Adobe Photoshop.
thanks in advance.
thanks in advance.
.Net all the way here!)
