Need to order some flowers
18 May 2009
Expat in LA
Hey guys,
So I need to order some flowers for a family member back at home in the UK. Ive never had to order them online for back at home before, so what are the best sites to use that you can recommend?
Ta!
Interflora.
Don't get it mistaken with a well known brand of dairy makers - She won't appreciate £30 worth of butter.
If you post what area of the UK you are sending them to i am sure someone could recomend a good local florist. The big services like interflora etc are ok but very expensive and you dont get the same service as you do from a small independent florist.
Have done this a couple of times recently, I look them up on the web , give them a call and it has worked out a hell of a lot cheaper than interflora :)
