Need to rebuild my pc in a lighter chassis
22 Dec 2002
Minehead
Hey all,
Currently I have all my hardware housed in a Coolermaster HAF 932, which while having as much room as a small tower block - is too heavy and bulky for me to be shifting around now.
I have the following components which can be reused but I'm open to suggestions if I can upgrade for not too much additional outlay!
3770k
16gb Corsair Ram
Corsair HX 650 professional
250gb Samsung 830 and a 120gb Sandisk SSD
4x Mechanical HDD's (was a striped array for games and a mirrored array for photos)
Don't have a z77 motherboard anymore as my delightful child decided to help me for the two seconds I wasn't looking by screwing up the socket pins with a screwdriver :/
So my thoughts are this : Get something like the BitFenix Prodigy M and buy a m-atx motherboard from somewhere of the z77 variety (second hand I guess is my only option) or failing that I'd like to buy a light ATX case and replace the motherboard that I did have for that? However, maybe it would be worth upgrading the whole lot now - however I read that new stuff is due out next year so I'd prefer to keep it to a motherboard and case if I can!
Any help much appreciated.
Thanks
You need to see what Z77 boards you can find, there were itx versions from Gigabyte/Asus etc.
Or mATX from all of them.
Then get a case based on that.
Morning Stulid!
Thanks for the reply, I figured I'd be kind of limited to Micro ATX as I want more sata ports than are typically found on itx boards! I quite like the look of the bitfenix case so will probably go with that as the price is reasonable and its not that heavy.
I just am not having much luck finding z77 boards. I'd hoped ocuk would have some clearance ones but no such luck!
Thanks :) That B grade board is just as expensive as it was when it was new! Ocuk's B-Grade pricing has gone wrong somewhere lately!
I'd love a little ITX build but just they don't have enough sata ports! Unless I used a NAS for photos etc instead!
