- 12 Jun 2011
Hi all,
I need to replace my GPU (Nvidea MSI 9800GX2)
i need something that is going to be same spec or better (for as cheap as possible) and has to have the spdif (2pin) input to run the sound through the gpu and out of the HDMI.
the reason i need a replacement is that my 3 pins on my spdif output on my MB is not laballed and i must have connected it to power pin (rather than ground)
which caused the lead to instantaniously melt/smoke.
this caused the little 2pin connection clip on the gpu to melt. so i can actually plug the 2pin spdif cable in either way (im not sure which way it should be) the pins are still there but i feel it maybe a little unsafe now.
on a side note can someone advise which way the plug should go in (black wire on left or right?)
