Need to replace my Logitech G35
9 Dec 2008
Personally I think the sound quality of the G35 is very good (Yes Ive never put a pair of £300 headphones on my head before though).
Only problem I have with the G35 is the cable. It really frustrates me, have to unplug to untangle every other day. I am considering going Wireless for my sound on PC.
I mostly play games and listen to music.
Please recommend me something decent that is wireless, as good as the G35 if not better. Dont worry about my budget aslong as its not £500.
I highly recommend Sennheiser for headphones / headsets.
I have never personally gone wireless for headphones however Sennheiser RS Series are wireless RS195, RS185, RS175.
But that would mean you require a separate mic, which isn't a bad thing. This could mean you would get better products overall than if you were to buy a headset.
