My parents have just signed up for broadband and they are having some connectivity issues. Basically their BT socket is in the hall but their is no power socket there and putting one in will be a bit of a task!
So, they need to run an extension so that their wireless router can get both power and a phone connection. They currently have one in place but it is 25m (with the excess cable stashed in the loft), of low cable quality and has a broken connector. Straight into the socket I was downloading open office at a steady 88kbps. via the extension I got 7 - 8 kbps!
What I'm wondering is what the best method is to wire a new one. Should I split the signal with a microfilter first then run a 10m cable to the router or should I run a 10m phone extension then split it just before the router. Or in graphical terms in case I didn't explain that very well...
Any help would be great!
