Need to upgrade,But im not educated in computer hardware.
21 Jun 2016
Help. I don't know what to write. I need a PC build that contains a 1080 GPU, 32gb DDR4 RAM Minimum, And an Intel i7 Processor. My problem is, I have no idea what motherboard I'll need, Which process is useful for value, and which of the 20 types of 1080 GPU's I should get.
Cosmetic wise i'm not too fussed but I need it to be silent, So because of this I don't know if its best to go Fan cooled, or Watercooled. I've also no experience in watercooling so thats a hard choice.
My needs for the PC, are to be able to run every currently available game, in a happy 50+ FPS in ultra settings, on a 1080p screen, Or on a 1080p Projector in Full Active 3D, or even for VR ( I bought the Vive 2 weeks ago) EDIT: Also would like to be able to stream in 60fps 1080p (if my upload speed can also handle it)
I'm assuming I'd need an x99 motherboard, and that the GPU dosn't really matter so long as it's a 1080 right? but Yeah.. I've no idea what I'm doing and I don't want to splash out £2500 on random bits to find they aren't compatible lol.
EDIT: Budget is below £3000, would rather be on the 1800-2200 side, but I don't mind going higer if needed
Thanks in advance for any advice or support.
Luke.
Sorry I should have mentioned it.
I have Monitors, Keyboard, Mouse, Headset already.
I'm in the need of a complete tower build (Preferably cube, but big enough for a possible SLI in the future) So I'll need MoBo, CPU, GPU, PSU, RAM, Wireless card, Sound card, Blu-ray Drive, and what ever else a PC needs to run.
Thats my Dxdiag.exe information if it helps. It's a pre-build MSI Nightblade PC.
System Information
Time of this report: 6/21/2016, 18:17:02
Machine name: LUKE
Operating System: Windows 10 Home 64-bit (10.0, Build 10586) (10586.th2_release_sec.160527-1834)
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-7851
BIOS: V3.2B0-W8
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
Memory: 16384MB RAM
Available OS Memory: 16312MB RAM
Page File: 6178MB used, 13066MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10586.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 970
Manufacturer: NVIDIA
Chip type: GeForce GTX 970
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_13C2&SUBSYS_31601462&REV_A1
Display Memory: 12163 MB
Dedicated Memory: 4007 MB
Shared Memory: 8155 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: G246HL
Monitor Id: ACR02FF
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um,nvwgf2um
Driver File Version: 10.18.0013.6472 (English)
Driver Version: 10.18.13.6472
DDI Version: 12
Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 21/03/2016 00:00:00, 17369448 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-5082-11CF-9A6E-6D111CC2C735}
Vendor ID: 0x10DE
Device ID: 0x13C2
SubSys ID: 0x31601462
Revision ID: 0x00A1
Driver Strong Name: oem21.inf:0f066de3ad0bda5c:Section045:10.18.13.6472:pci\ven_10de&dev_13c2
Rank Of Driver: 00D12001
Video Accel:
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Sound Devices
Description: Headset Earphone (12- Corsair VOID RGB Wireless Gaming Headset)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_1B1C&PID_1B23&REV_0000&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 10.00.10586.0000 (English)
WHQL Logo'd: Yes
Date and Size: 29/02/2016 00:00:00, 131584 bytes
Other Files:
Driver Provider: Corsair
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Stereo Mix (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7535 (English)
Date and Size: 6/24/2015 22:57:00, 4504320 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Headset Microphone (12- Corsair VOID RGB Wireless Gaming Headset)
Default Sound Capture: No
Default Voice Capture: No
Date and Size: 10/30/2015 08:17:19, 131584 bytes
Cap Flags: 0x1
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Corsair STRAFE RGB Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B20
FF Driver: n/a
Device Name: Corsair Gaming Scimitar RGB Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B1E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Corsair VOID RGB Wireless Gaming Headset
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B24
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Controller (XBOX 360 For Windows)
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x028E
FF Driver: n/a
Device Name: Corsair composite virtual input device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1BF0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Hid Interface
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B23
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (xHCI)
| Vendor/Product ID: 0x8086, 0x8C31
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 4/23/2016 05:56:52, 534872 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 10/30/2015 08:17:23, 159072 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 10/30/2015 08:17:23, 38400 bytes
| | | Driver: hidclass.sys, 5/28/2016 05:23:26, 155136 bytes
| | | Driver: hidparse.sys, 10/30/2015 08:17:23, 40448 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 10/30/2015 08:17:23, 36864 bytes
| | | | Driver: kbdclass.sys, 10/30/2015 08:17:23, 62304 bytes
| | | Service: HidUsb
| | | | Service: kbdhid
| | Service: usbccgp
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 10/30/2015 08:17:23, 32256 bytes
| | | | Driver: mouclass.sys, 10/30/2015 08:17:23, 59232 bytes
| | | Service: HidUsb
| | | | Service: mouhid
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x1B1C, 0x0000
| Service: kbdhid
| Service: kbdhid
| Service: mouhid
| Service: mouhid
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 10.6 GB
Total Space: 242.9 GB
File System: NTFS
Model: TS256GSSD370
Drive: D:
Free Space: 389.6 GB
Total Space: 1884.9 GB
File System: NTFS
Model: ST2000DM001-1ER164
Drive: E:
Model: HL-DT-ST DVDRAM GA50N
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:22, 173568 bytes
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_78511462&REV_06\3&11583659&1&00
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_8C3A&SUBSYS_78511462&REV_04\3&11583659&1&B0
Driver: C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys, 9.05.0015.1730 (English), 2/10/2015 02:14:00, 99288 bytes
Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\3f3ca95b-3978-4168-b47b-5444f42d6c89.devicemetadata-ms, 2/10/2015 02:14:00, 938 bytes
Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\46a6fdbe-c823-4579-bab6-35f67e01f793.devicemetadata-ms, 2/10/2015 02:14:00, 833 bytes
Driver: C:\WINDOWS\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (English), 2/10/2015 02:14:00, 1795952 bytes
Name: Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26
Device ID: PCI\VEN_8086&DEV_8C26&SUBSYS_78511462&REV_05\3&11583659&1&E8
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:23, 95584 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:23, 454496 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:23, 500064 bytes
Name: Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D
Device ID: PCI\VEN_8086&DEV_8C2D&SUBSYS_78511462&REV_05\3&11583659&1&D0
Name: NVIDIA GeForce GTX 970
Device ID: PCI\VEN_10DE&DEV_13C2&SUBSYS_31601462&REV_A1\4&32C56422&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 458296 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 3/22/2016 05:08:04, 1320044 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_d0dcb8f2b4b5cdcd\NvCplSetupInt.exe, 1.00.0005.0000 (English), 3/22/2016 05:08:04, 97007624 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 3/22/2016 05:08:04, 20536 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 158048 bytes
Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 106024 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 3/22/2016 05:08:04, 20536 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 187728 bytes
Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 126416 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 3/22/2016 05:08:04, 26629 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 3/22/2016 05:08:04, 849976 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 406976 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 3/22/2016 05:08:04, 74003 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.6472 (English), 3/22/2016 05:08:04, 440256 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.6472 (English), 3/22/2016 05:08:04, 721976 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.02.0011.0000 (English), 3/22/2016 05:08:04, 201664 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.02.0011.0000 (English), 3/22/2016 05:08:04, 213952 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvlddmkm.sys, 10.18.0013.6472 (English), 3/25/2016 02:23:12, 12659136 bytes
Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 960056 bytes
Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 889400 bytes
Driver: C:\WINDOWS\system32\NvIFROpenGL.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 425016 bytes
Driver: C:\WINDOWS\system32\nv-vk64.json, 3/22/2016 05:08:04, 139 bytes
Driver: C:\WINDOWS\system32\nvDecMFTMjpeg.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 385080 bytes
Driver: C:\WINDOWS\system32\nvEncMFTH264.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 786872 bytes
Driver: C:\WINDOWS\system32\nvEncMFThevc.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 784824 bytes
Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 379296 bytes
Driver: C:\WINDOWS\system32\nvapi64.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 3685280 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 3/22/2016 05:08:04, 42923576 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 20906168 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.6472 (English), 3/22/2016 05:08:04, 2614208 bytes
Driver: C:\WINDOWS\system32\nvd3dumx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 17369448 bytes
Driver: C:\WINDOWS\system32\nvfatbinaryLoader.dll, 3/22/2016 05:08:04, 678520 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 3/22/2016 05:08:04, 38050 bytes
Driver: C:\WINDOWS\system32\nvinitx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 176064 bytes
Driver: C:\WINDOWS\system32\nvmcumd.dll, 3/22/2016 05:08:04, 601936 bytes
Driver: C:\WINDOWS\system32\nvoglshim64.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 151368 bytes
Driver: C:\WINDOWS\system32\nvoglv64.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 31594432 bytes
Driver: C:\WINDOWS\system32\nvopencl.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 21364536 bytes
Driver: C:\WINDOWS\system32\nvptxJitCompiler.dll, 3/22/2016 05:08:04, 10550552 bytes
Driver: C:\WINDOWS\system32\nvumdshimx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 546328 bytes
Driver: C:\WINDOWS\system32\nvwgf2umx.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 20074728 bytes
Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 751552 bytes
Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 695864 bytes
Driver: C:\WINDOWS\SysWow64\NvIFROpenGL.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 379448 bytes
Driver: C:\WINDOWS\SysWow64\nv-vk32.json, 3/22/2016 05:08:04, 139 bytes
Driver: C:\WINDOWS\SysWow64\nvDecMFTMjpeg.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 348216 bytes
Driver: C:\WINDOWS\SysWow64\nvEncMFTH264.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 632336 bytes
Driver: C:\WINDOWS\SysWow64\nvEncMFThevc.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 630776 bytes
Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 317656 bytes
Driver: C:\WINDOWS\SysWow64\nvapi.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 3263480 bytes
Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 3/22/2016 05:08:04, 37567424 bytes
Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 17349776 bytes
Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.6472 (English), 3/22/2016 05:08:04, 2260024 bytes
Driver: C:\WINDOWS\SysWow64\nvd3dum.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 14226672 bytes
Driver: C:\WINDOWS\SysWow64\nvfatbinaryLoader.dll, 3/22/2016 05:08:04, 572096 bytes
Driver: C:\WINDOWS\SysWow64\nvinit.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 153392 bytes
Driver: C:\WINDOWS\SysWow64\nvoglshim32.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 129208 bytes
Driver: C:\WINDOWS\SysWow64\nvoglv32.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 25350080 bytes
Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 6.14.0013.6472 (English), 3/22/2016 05:08:04, 17755928 bytes
Driver: C:\WINDOWS\SysWow64\nvptxJitCompiler.dll, 3/22/2016 05:08:04, 8659472 bytes
Driver: C:\WINDOWS\SysWow64\nvumdshim.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 448824 bytes
Driver: C:\WINDOWS\SysWow64\nvwgf2um.dll, 10.18.0013.6472 (English), 3/22/2016 05:08:04, 17328008 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_d0dcb8f2b4b5cdcd\VulkanRT-Installer.exe, 1.00.0005.0001 (English), 3/22/2016 05:08:04, 13573832 bytes
Driver: C:\WINDOWS\system32\nvdispco6436472.dll, 2.00.0043.0004 (English), 3/22/2016 05:08:04, 1922496 bytes
Driver: C:\WINDOWS\system32\nvdispgenco6436472.dll, 2.00.0021.0002 (English), 3/22/2016 05:08:04, 1571776 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_8C20&SUBSYS_F8511462&REV_05\3&11583659&1&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:18, 79872 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:19, 97280 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.10586.0212 (English), 3/29/2016 08:34:50, 333824 bytes
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_78511462&REV_0C\4&23BCA8CC&0&00E3
Driver: C:\WINDOWS\system32\DRIVERS\Rt630x64.sys, 8.23.1126.2013 (English), 2/10/2015 02:13:59, 838872 bytes
Driver: C:\WINDOWS\system32\RtNicProp64.dll, 1.02.0000.0006 (English), 2/10/2015 02:13:59, 73800 bytes
Device ID: PCI\VEN_8086&DEV_0C01&SUBSYS_78511462&REV_06\3&11583659&1&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.10586.0420 (English), 5/28/2016 06:07:45, 331616 bytes
Name: Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_8C02&SUBSYS_78511462&REV_05\3&11583659&1&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStorA.sys, 12.08.0002.1000 (English), 2/10/2015 02:14:58, 644968 bytes
Name: Intel(R) Dual Band Wireless-AC 3160
Device ID: PCI\VEN_8086&DEV_08B3&SUBSYS_00708086&REV_83\4&19DB98BF&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\Netwbw02.sys, 17.15.0000.0005 (English), 10/30/2015 08:17:19, 3485696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\Netwfw02.dat, 10/30/2015 08:17:19, 3549068 bytes
Device ID: PCI\VEN_8086&DEV_8C22&SUBSYS_78511462&REV_05\3&11583659&1&FB
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_8C50&SUBSYS_78511462&REV_05\3&11583659&1&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.10586.0000 (English), 10/30/2015 08:17:23, 18784 bytes
Device ID: PCI\VEN_8086&DEV_8C18&SUBSYS_78511462&REV_D5\3&11583659&1&E4
Device ID: PCI\VEN_8086&DEV_8C10&SUBSYS_78511462&REV_D5\3&11583659&1&E0
Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_8C31&SUBSYS_78511462&REV_05\3&11583659&1&A0
Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.10586.0212 (English), 3/29/2016 09:21:40, 378208 bytes
Device ID: PCI\VEN_10DE&DEV_0FBB&SUBSYS_31601462&REV_A1\4&32C56422&0&0108
Device ID: PCI\VEN_8086&DEV_8C16&SUBSYS_78511462&REV_D5\3&11583659&1&E3
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.10586.0063
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.10586.0063
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.10586.0063
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.10586.0063
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.10586.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.10586.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.10586.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.10586.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.10586.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.10586.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.10586.0071
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.10586.0000
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.10586.0071
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.10586.0071
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.10586.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.10547.1000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.10586.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.10586.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.10586.0071
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.10586.0071
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10586.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.10586.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.10586.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.10586.0000
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10586.0035
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.10586.0071
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.10586.0071
DV Splitter,0x00600000,1,2,qdv.dll,10.00.10586.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.10586.0071
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.10586.0035
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.10586.0071
Video Renderer,0x00800001,1,0,quartz.dll,10.00.10586.0071
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.10586.0000
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.10586.0071
Video Renderer,0x00400000,1,0,quartz.dll,10.00.10586.0071
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.10586.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.10586.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.10586.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.10586.0063
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10586.0035
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.10586.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.10586.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.10586.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.10586.0063
Null Renderer,0x00200000,1,0,qedit.dll,10.00.10586.0063
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.10586.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.10586.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.10586.0000
Smart Tee,0x00200000,1,2,qcap.dll,10.00.10586.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.10586.0071
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.10586.0071
Wave Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.10586.0071
File stream renderer,0x00400000,1,1,quartz.dll,10.00.10586.0071
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.10547.1000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.10586.0000
AVI Mux,0x00200000,1,0,qcap.dll,10.00.10586.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.10586.0071
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.10586.0071
File Source (URL),0x00400000,0,1,quartz.dll,10.00.10586.0071
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.10586.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.10586.0071
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.10586.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.10586.0071
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.10586.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.10586.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.10586.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.10586.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.10586.0071
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.10586.0063
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.10586.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.10586.0071
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.10586.0071
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.10586.0071
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.10586.0071
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.10586.0071
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.10586.0071
Audio Capture Sources:
Stereo Mix (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.10586.0000
Headset Microphone (12- Corsair VOID RGB Wireless Gaming Headset),0x00200000,0,0,qcap.dll,10.00.10586.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.10586.0000
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.10586.0000
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.10586.0000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.10586.0071
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.10586.0071
WDM Streaming Capture Devices:
Mic in at rear panel (Pink),0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Line in at rear panel (Blue),0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Line in at front panel (Pink),0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Line in at front panel (Green),0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Line in at rear panel (Green),0x00200000,1,1,ksproxy.ax,10.00.10586.0063
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio 2nd output,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.10586.0063
Corsair Audio Device,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10586.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.10586.0000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.10586.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.10586.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.10586.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.10586.0000
PTFilter,0x00200000,0,0,EncDec.dll,10.00.10586.0000
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.10586.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Headset Earphone (12- Corsair VOID RGB Wireless Gaming Headset),0x00200000,1,0,quartz.dll,10.00.10586.0071
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.10586.0071
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.10586.0071
DirectSound: Headset Earphone (12- Corsair VOID RGB Wireless Gaming Headset),0x00200000,1,0,quartz.dll,10.00.10586.0071
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpeg.dll, 10.18.0013.6472
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.10586.0000
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.10586.0000
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.10586.0000
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.10586.0000
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.10586.0000
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.10586.0000
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.10586.0000
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.10586.0000
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 10.18.0013.6472
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevc.dll, 10.18.0013.6472
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.10586.0000
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.10586.0000
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.10586.0000
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.10586.0000
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.10586.0035
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.10586.0000
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.10586.0000
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.10586.0000
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.10586.0000
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.10586.0000
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.10586.0000
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.10586.0122
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.10586.0000
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.10586.0000
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.10586.0063
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.10586.0000
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.10586.0122
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.10586.0122
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.10586.0063
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.10586.0122
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.10586.0000
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.10586.0063
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.10586.0122
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.10586.0122
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.10586.0063
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.10586.0000
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.10586.0122
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, winmde.dll, 12.00.10586.0000
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.10586.0122
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.10586.0000
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.10586.0063
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.10586.0000
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.10586.0035
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.10586.0000
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.10586.0000
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.10586.0000
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.10586.0000
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.10586.0000
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.10586.0000
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.10586.0122
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.10547.1000
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableVideoProcessors = 1
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: PnPGenericDriverFound
Response: Not available
Cab Id: 0
Problem signature:
P1: x64
P2: HID\VID_1B1C&PID_1B23&REV_0000&MI_03&Col01
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Event Name: PnPRequestAdditionalSoftware
Cab Id: 0
Problem signature:
P1: x64
P2: HID\VID_1B1C&PID_1B23&REV_0000&MI_03&Col02
P3: 10.0.0.0
P4: 0809
P5: input.inf
P6: *
P7:
P8:
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: x64
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: x64
P2: HID\VID_1B1C&PID_1B23&REV_0000&MI_03&Col03
P3: 10.0.0.0
P4: 0809
P5: input.inf
P6: *
P7:
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: x64
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: x64
P2: USB\VID_1B1C&PID_1B23&REV_0000&MI_03
P3: 10.0.0.0
P4: 0809
P5: input.inf
P6: *
P7:
P8:
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: x64
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: x64
P2: USB\VID_1B1C&PID_1B23&REV_0000&MI_00
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P1: x64
P2: HID\VID_170D&PID_0100&REV_0200
P3: 10.0.0.0
P4: 0809
P5: input.inf
P6: *
P7:
P8:
P9:
P10:
+++ WER9 +++:
Cab Id: 0
Problem signature:
P1: x64
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
It's not a K, It's a normal 4790. I'm going to be keeping this build complete and giving it to my little sister because my parents just bought her the Vive but her current pc cant handle the vive.
The Gigabyte
GA-X99-Ultra Gaming Intel X99 (Socket 2011) DDR4 ATX Motherboard, Is this a good quality motherboard? I'm assuming it is because of it's value.
Ah nice, I've not used such a big CPU fan before so it's going to be interesting to check out. Also a question about the RAM, Does the Speed make much of a difference? For example would it be better to go for DDR4 3400MHZ+ or go for a lower one like your suggestion of the 2666MHz?
I picked it because of the colour and price, 8pack said in another thread it doesnt matter to much on X99, Skylake does benefit from faster stuff.
I made a few changes, I probably messed up the compatibilty but I changed some colours about, upped the RAM and the CPU, and added a second GPU How does this look?
My basket at Overclockers UK:
Total: £2,631.72
(includes shipping: £0.00)
//img.overclockers.co.uk/media/image/thumbnail/MB549GI_142379_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/CP611IN_142127_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/CA005PT_93366_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/CA007PT_93512_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/CA023SF_101194_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/HD214SA_115863_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/HS051AL_110155_105x105.png//img.overclockers.co.uk/media/image/thumbnail/MY197CR_116237_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/CA050SF_121635_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/SW172MS_114227_105x105.jpg//img.overclockers.co.uk/media/image/thumbnail/GX089KF_142864_105x105.jpg
Everything is compatible, but if you are gaming at 1080p 60Hz resolution then 2 x GTX 1080's is major overkill.
You can get Windows 10 on USB if you don't want to install an optical drive.
I'm fine with the Optical drive install, I'll be getting a seperate SSD just for the OS :D.
Before I follow through with my package, is there a huge differecnce between z170 and x99 Mobos?
Just had another mess about, Managed to lower the value, while keeping the PC around the same specs, I think...
Total: £1,566.79
I didn't notice the amount of Ram, but Stulid is correct in that 32GB is a lot. If you are just gaming then go with 16GB.
The optical drive is going to stand out a bit with the White version of the Luxe. I would go with an external USB drive.
