My current system is as follows
AMD Phenom II 955 BE (overlocked to 3.8ghz)
Gigabyte MA790XT-UD4P
Radeon 69702gb
4GB Ram
I want to upgrade the CPU to an Intel chip as i mainly play Iracing and Arma 2 both of which run considerably better on Intel chips than they do AMD ones ! Also i want to ditch this stupid titan fenrir cooler i have which takes up my entire case space !
My problem is that im not sure what Intel chips my motherboard supports and if i do get a new CPU will i need to get a new motherboard as well... ideally i want to keep same motherboard to keep costs as low as possible.
Could someone recommend me a good cpu to go for, it doesn't need to be the best ever, just something which is a decent upgrade from what i currently have and is compatible with my motherboard... or if there is nothing compatible with the motherboard maybe someone could suggest a good motherboard/cpu combo !
Radeon 69702gb
4GB Ram
